NICO Club
Nissan Forums | Infiniti Forums
Edub1’s SOHC guide to replacing valve seals
December 10, 2009 by Aaron
1989-1990 Nissan 240sx
$1.50 per seal
4-8 hours
NICOclub Rating System
Edub1
Tools:
– Air compressor – 120psi
– Air hold tool – Murray’s
– Universal spring compressor
– Pointer style retrieval magnet (must have)
Procedure:
1)Position car on clean hard surface – IMPORTANT
2)Remove valve cover
3)Remove rocker arm assemblies leaving cam in place
4)Remove spark plug and screw in air hold tool
Removing the rocker assemblies will close all the valves so there is no need to rotate motor.Compress cylinder to 140PSI as per FSM.120PSI worked fine for me.
5)Compress valve until you have enough room to extract the valvelock shims from the top; pushing down and wiggling helps.Use your magnet to extract the shims.
6)Pull of old seal with a Channel Lock.
7)Put on new ones.Intake seals can be seated with the help of a deep well socket and light tapping.
8)Replace spring and valve lock shims.You will drop the shims several times.If you are on a clean hard surface use your magnet to retrieve them.If you are not on a clean hard surface you will never find them in a million years.Release spring compressor.
9)Install rocker assembly.Tighten from center outward.Torque to 27 – 30 ft lb or 37 – 41 NM
10)Replace valve cover – you are done.
IMPORTANT: Resist the temptation to observe the rocker arms by starting motor with valve cover off.Massive amounts of oil will spray everywhere.
  • KA24e to KA24de swap – Step-by-step
  • 240SX How To: Removing/Replacing your PS pump
  • How-to: Build Your Own Oil Cooler
  • 240sx:A Buying Guide
  • Vroom-Chirp’s Lit Sleepy Eyes Writeup
  • LED interior lights: Trunk Lamp
  • S13 Automatic to Manual Seat Belt Conversion
  • 91-94 240sx Vacuum Diagrams – Component Locaters
  • Installing an oil cooler on an RB25DET
  • How to: Repacking Wheel Bearings
Filed Under: 240sx Articles, Nissan articles Tagged With: ka24e, replace, seal, valve
1987 Nissan Full Lineup Dealership Brochure
Strategic Shopping
Be Aware – Scammers Targeting Car Sellers
Battery Life Information for your Nissan Vehicle
Checking Tire Pressures – Why it’s Important
DIY Replace Drive Belts and Idler Pully on VQ35 Pathfinder
Could This Be the Best $30 You Spend on your Truck?
Roadmaster Active Suspension for Project Titan
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc. They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti. Information Copyright © 2000-2018 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
