Step 1:
Check to ensure that you have the correct piece and that it fits.
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2174.jpg[/img]
Step 2:
Warm up each piece. You can either put them on your vents with the heat on high (warm) or use a hair dryer.
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2171.jpg[/img]
Step 3:
Use alcohol pad to clean the area.
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2172.jpg[/img]
Step 4:
Use the 3M adhesion that they provide you. Use on the corners. Do not apply to actual product.
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2173.jpg[/img]
Step 5:
Peel a portion of the tape back.
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2175.jpg[/img]
Step 6:
Place it on and slowly peel back the tape as you align it.
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2176.jpg[/img]
Step 7:
Using a cloth, push down on the piece you have just installed. This will ensure that it bonds properly to the dash.
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2177.jpg[/img]
Finished product:
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2178.jpg[/img]
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2183.jpg[/img]
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2186.jpg[/img]
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2184.jpg[/img]
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2160.jpg[/img]
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2152.jpg[/img]
[img]http://i413.photobucket.com/albums/pp215/ashleycabral/IMG_2150.jpg[/img]
