NICOclub.com purchases, downloads, and maintains a comprehensive directory of Infiniti Factory Service Manuals for use by our registered members.
While we wouldn’t prevent anyone from using this information, we’d hope you would appreciate our efforts enough to frequent the forums here, rather than using them as a reference on other websites.
Select your vehicle to access the Factory Service Manuals:
INFINITI CARS
- 1991
- 1992
- 20L_4CYL_VIN_C.PDF
- 97V071000_REAR_SEAT_BUCKLES.PDF
- 97V072000_FUEL_FILLER_TUBE.PDF
- ABBREVIATIONS.PDF
- AC_COMPRESSOR_OIL_CHECKING.PDF
- AC_COMPRESSOR_SERVICING.PDF
- AC_HEATER_SYSTEM_MANUAL.PDF
- AC_HEATER_SYSTEM_UNIFORM_IN.PDF
- AC_SYSTEM_GENERAL_DIAGNOSTI.PDF
- AC_SYSTEM_GENERAL_SERVICING.PDF
- AC_SYSTEM_PRECAUTIONS.PDF
- ALTERNATOR_AND_REGULATOR_HI.PDF
- ANTI_LOCK_BRAKE_SAFETY_PREC.PDF
- ANTI_LOCK_BRAKE_SYSTEM.PDF
- AXLE_SHAFTS_FRONT.PDF
- A__ENGINE_VIN_ID.PDF
- BRAKE_SYSTEM.PDF
- BRAKE_SYSTEM_UNIFORM_INSPEC.PDF
- B_EMISSION_APPLICATION.PDF
- CLUTCH.PDF
- COMPUTER_RELEARN_PROCEDURES.PDF
- COOLING_SYSTEM_SPECIFICATIO.PDF
- CRUISE_CONTROL_SYSTEM.PDF
- C_SPECIFICATIONS.PDF
- DEFOGGER_REAR_WINDOW.PDF
- DRIVETRAIN_SYSTEMS_UNIFORM_.PDF
- DRIVE_BELT_ADJUSTMENT_SPECI.PDF
- D_ADJUSTMENTS.PDF
- ELECTRICAL_COMPONENT_LOCATO.PDF
- ELECTRICAL_SYSTEM_UNIFORM_I.PDF
- ELECTROSTATIC_DISCHARGE_WAR.PDF
- EMISSION_CONTROL_VISUAL_INS.PDF
- ENGINE_OVERHAUL_PROCEDURES_.PDF
- ENGINE_SYSTEMS_UNIFORM_INSP.PDF
- EXHAUST_SYSTEM_UNIFORM_INSP.PDF
- E_THEORY_OPERATION.PDF
- FUSES_AND_CIRCUIT_BREAKERS.PDF
- F_BASIC_TESTING.PDF
- GEAR_TOOTH_CONTACT_PATTERNS.PDF
- GENERAL_COOLING_SYSTEM_SERV.PDF
- G_TESTS_WITH_CODES.PDF
- HOW_TO_USE_SYSTEM_WIRING_DI.PDF
- H_TESTS_WITHOUT_CODES.PDF
- INSTRUMENT_PANEL.PDF
- I_SYSTEM_COMPONENT_TESTS.PDF
- JACKING_AND_HOISTING.PDF
- J_PIN_VOLTAGE_CHARTS.PDF
- K_SENSOR_RANGE_CHARTS.PDF
- L_WIRING_DIAGRAMS.PDF
- MAINTENANCE_INFORMATION.PDF
- METRIC_CONVERSIONS.PDF
- MIRRORS_POWER.PDF
- M_VACUUM_DIAGRAMS.PDF
- N_REMOVE_INSTALLL_OVERHAUL.PDF
- PRE_ALIGNMENT_CHECKS.PDF
- P_EGR_FUNCTION_TESTING.PDF
- RIDING_HEIGHT_ADJUSTMENT.PDF
- SCHEDULED_SERVICES.PDF
- SERVICE_INDICATOR_AND_WARNI.PDF
- STARTER_HITACHI_AND_MITSUBI.PDF
- STEERING_COLUMN.PDF
- STEERING_COLUMN_SWITCHES.PDF
- STEERING_SYSTEM_POWER.PDF
- STEERING_UNIFORM_INSPECTION.PDF
- SUSPENSION_FRONT.PDF
- SUSPENSION_REAR.PDF
- SUSPENSION_UNIFORM_INSPECTI.PDF
- SYMPTOM_CHECK_LIST.PDF
- SYSTEM_WIRING_DIAGRAMS.PDF
- TRANSMISSION_REMOVAL_AND_IN.PDF
- TRANSMISSION_SERVICING_AT.PDF
- TRANSMISSION_SERVICING_MT.PDF
- TROUBLE_SHOOTING_BASIC_PROC.PDF
- WAVEFORMS_INJECTOR_PATTERNS.PDF
- WHEEL_ALIGNMENT_SPECS_AND_P.PDF
- WHEEL_ALIGNMENT_THEORY_OPER.PDF
- WIPER_WASHER_SYSTEM.PDF
- WIRING_DIAGRAMS.PDF
- WIRING_DIAGRAM_SYMBOLS.PDF
- W_WAVEFORM__INJECTOR__20L_S.PDF
- 1993
- 1994
- Automatic Transmission
- Body
- Brake System
- Clutch System
- Engine Control System
- Electrical System
- Engine Mechanical
- Front Axle and Suspension
- Accelerator Control, Fuel and Exhaust Systems
- foldout.pdf
- Intro - Table of Contents
- General Information
- Heater and Air Conditioning System
- Alphabetical Index
- Engine Lubrication and Cooling System
- Maintenance
- Manual Transaxle
- Rear Axle and Suspension
- Steering System
- 1995
- Body
- Brake System
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Steering System
- 1996
- Brake System
- Body and Trim
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Restraint System
- Steering System
- 1999
- Front and Rear Axle
- Brake System
- Body and Trim
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Restraint System
- Starting and Charging System
- Steering System
- Front and Rear Suspension
- 2000
- Brake System
- Body and Trim
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Restraint System
- Steering System
- 2001
- Brake System
- Body and Trim
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Restraint System
- Steering System
- 2002
- Brake System
- Body and Trim
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Restraint System
- Steering System
G37 performance and appearance bargains on Amazon!
The nearly 50-50 weight distribution, available six speed transmission, Brembo brakes, limited slip differential, and mid mounted 260 horsepower engine made for a chassis that handled well and had the power to back it up.
The G35 was succeeded by the G37. Many of the components were shared, but the driving dynamics were improved. The engine would now make 328 horsepower, with an available seven speed automatic transmission, 4 piston front brakes & 2 piston rear brakes (sport models), paddle shifters (G37S model), and a viscous limited slip differential. The G37 is available as a coupe, sedan, and convertible.
Additionally, there is a sportier option for the G series named the G37 IPL. IPL stands for Infiniti Performance Line. The engine received a bump in horsepower, suspension revisions, and sportier body styling.
In 2010, one other option also became available in the G model line. The introduction of the G25 uses a smaller displacement V6, an automatic transmission, is available with rear wheel or all wheel drive and is otherwise identical to the G37.
The Q40 debuted in 2015. While it was originally supposed to be replaced by the Q50, Infiniti kept the [formerly G37] around as the renamed Q40 because of continued demand. One of Infiniti’s top sellers, the Q40 got a big price cut and represents Infiniti’s entry-level offering.
- G35
- Coupe
- 2003
- Accelerator Control System
- Automatic Cruise Control System
- Automatic Air Conditioner
- Audio, Visual and Navigation System
- Body Control System
- Body, Lock and Security System
- Brake System
- Brake Control System
- Clutch System
- Engine Cooling System
- Driver Information System
- Exterior and Interior
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Glass and Window System
- Instrument Panel
- LAN System
- Lighting System
- Engine Lubrication System
- Maintenance
- Manual Transaxle
- Parking Brake System
- Power Supply, Ground and Circuit Elements
- Propeller Shaft
- Power Steering System
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Road Wheels and Tires
- Wiper and Washer
- 2004
- Brake System
- Clutch System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Manual Transaxle
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- 2005
- Brake System
- Clutch System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Manual Transaxle
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering Control System
- Wiper and Washer
- 2006
- Brake System
- Clutch System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Manual Transaxle
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- 2007
- Brake System
- Clutch System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Manual Transaxle
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- Sedan
- 2003
- Brake System
- Clutch System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Manual Transaxle
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- 2004
- Brake System
- Clutch System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Manual Transaxle
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- 2004.5
- Brake System
- Clutch System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Manual Transaxle
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2005
- Brake System
- Clutch System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Manual Transaxle
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2006
- Brake System
- Clutch System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Manual Transaxle
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2007
- Automatic Drive Positioner
- Brake System
- Body Repair Manual
- Cruise Control System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior Lighting System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Heater and Air Conditioning Control System
- Horn
- Interior Lighting System
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Meter, Warning Lamp and Indicator
- Power Control System
- Power Window Control System
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Security Control System
- SRS Airbag Control System
- Steering System
- Starting System
- Transaxle and Transmission
- Ventilation System
- Warning Chime System
- Wiper and Washer
- 2008
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat Belt Control System
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- G37
- Convertible
- 2009
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- HA .pdf
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- SB .pdf
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2010
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- HA .pdf
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- SB .pdf
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2011
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2012
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2013
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- Coupe
- 2008
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2009
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2010
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- HA .pdf
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- SB .pdf
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2011
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2012
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2013
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- G37 Accessory
- Sedan
- 2009
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- HA .pdf
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- SB .pdf
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2010
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- HA .pdf
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- SB .pdf
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2011
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2012
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2013
- Brake System
- Charging System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- Q40
- 2015
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
The Q50 contains many of Infiniti’s firsts: a drive by wire steering system, DAS – Direct Adaptive Steering (an industry first), a dual screen infotainment system (separation of climate control, navigation, safety features, and audio) which will help keep the necessities closer to hand, and an available turbo four cylinder and diesel option.
- 2014 Q50
- Brake System
- Charging System
- Driver Assistance System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- FWD1.pdf
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2015 Q50
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Drive Mode System
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2016 Q50
- acc-accelerator_control_system.pdf
- adp-automatic_drive_positioner.pdf
- av-audio_visual_navigation_system.pdf
- bcs-body_control_system.pdf
- br-brake_system.pdf
- brc-brake_control_system.pdf
- brm-body_repair.pdf
- ccs-cruise_control_system.pdf
- chg-charging_system.pdf
- co-engine_cooling_system.pdf
- das-driver_assistance_system.pdf
- def-defogger.pdf
- dlk-door_lock.pdf
- dln-driveline.pdf
- dms-drive_mode_system.pdf
- ec4-engine_control_system(gasoline in-line4).pdf
- ec6-engine_control_system(gasoline v6).pdf
- em-engine_mechanical.pdf
- ex-exhaust_system.pdf
- exl-exterior_lighting_system.pdf
- ext-exterior.pdf
- fax-front_axle.pdf
- fl-fuel_system.pdf
- fsu-front_suspension.pdf
- fwd-quick_reference_index.pdf
- gi-general_information.pdf
- gw-glass_window_system.pdf
- ha-heater_air_conditioning_system.pdf
- hac-heater_air_conditioning_control_system.pdf
- hrn-horn.pdf
- idx-alphabetical_index.pdf
- inl-interior_lighting_system.pdf
- int-interior.pdf
- ip-instrument_panel.pdf
- lan-lan_system.pdf
- lu-engine_lubrication_system.pdf
- ma-maintenance.pdf
- mir-mirrors.pdf
- mwi-meter_warning_lamp_indicator.pdf
- pb-parking_brake_system.pdf
- pcs-power_control_system.pdf
- pg-power_supply_ground_circuit_elements.pdf
- pwc-power_window_control_system.pdf
- pwo-power_outlet.pdf
- rax-rear_axle.pdf
- rf-roof.pdf
- rsu-rear_suspension.pdf
- sb-seat_belt.pdf
- sbc-seat_belt_control_system.pdf
- scs-suspension_control_system.pdf
- se-seat.pdf
- sec-security_control_system.pdf
- sr-srs_airbag.pdf
- src-srs_airbag_control_system.pdf
- st-steering_system.pdf
- stc-steering_control_system.pdf
- str-starting_system.pdf
- tm-transaxle_transmission.pdf
- vtl-ventilation_system.pdf
- wcs-warning_chime_system.pdf
- wt-road_wheel_tires.pdf
- ww-wiper_washer.pdf
- I30
- 1996
- 1996_I30_Body_Repair_Manual.pdf
- Brake System
- Body and Trim
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Restraint System
- Steering System
- 1997
- Brake System
- Body and Trim
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Restraint System
- Steering System
- 1998
- Brake System
- Body and Trim
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Restraint System
- Steering System
- 1999
- Brake System
- Body and Trim
- Clutch System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Manual Transaxle
- Restraint System
- Steering System
- 2000
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- Maintenance
- Restraint System
- Steering System
- 2001
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- I35
- 2002
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 2003
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 2004
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 1993
- 1994
- Body
- Brake System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Propeller Shaft and Diffeential Carrier
- Steering System
- 1995
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 1996
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 1997
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
The refreshed M35/45 debuted in 2006. The new car was based on an improved G series platform with optional V6 and V8 engines. Both models are available in all wheel drive and ATTESA. The M45 received a revised multi-link suspension and double wishbone suspension which provides a sporty, comfortable ride. The M received high accolades such as Interior of the Year, a IIHS safety pick, and an award for the fastest production hybrid. The M is currently on its fourth incarnation, and in 2014, Infiniti renamed the lineup of M sedans to “Q70.”
- 2003
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- 2004 M45
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- 2006 M45-M35
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2007 M45-M35
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2008
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- FFD.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2009
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- FFD.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2010
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- FFD.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2011
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Drive Mode System
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2012
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2013
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Drive Mode System
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- M Hybrid
- Brake System
- Clutch System
- Defogger
- Door and Lock
- Driveline
- Drive Mode System
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Hybrid Battery System
- Hybrid Control System
- HCO.pdf
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- TMS.pdf
- VSP.pdf
- Wiper and Washer
Sales for the Q were disappointing despite excellent reviews by the press. Some felt the lagging sales were due to its more dramatic, European inspired styling. But many felt it was more due to a controversial advertising campaign during its crucial launch, which excluded pictures of the car or even a description of it. As a result, the Q45 ended up getting compared mostly to the similarly priced (but arguably more reliable) LS400, a car that appealed to a traditional non-sporty luxury car buyer and subsequently created an uphill battle for Infiniti to make the Q’s more driver oriented character better known to the market.
In 1997, the second generation Q45 made a change in direction away from sportiness and more toward luxury. The new body had a more traditional luxury car look and featured a smaller, slightly less powerful 4.1L V8. All of the luxury goodies were there, including some new ones.
The 2002-2006 model years were the highest powered and most luxurious of the Q’s lifespan, with a 340 horsepower engine, sleek styling, 8 way power front and passenger seats. The 3rd generation Q represented a minor shift, but this time back in the sporty direction. In addition to a sleeker looking body, power was now provided by a new 4.5L V8 that pumped out 340hp. The addition of the Sport package added active dampening suspension which allowed the Q to drive like a sporty luxury sedan. But it was not enough to save the Q from extinction. Due to slow sales, the Q45 was superseded by the M35/45.
- 1990 Q45 Body Repair Manual.pdf
- 1991.pdf
- 1992.pdf
- 1993.pdf
- 1994
- Body
- Brake System
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Steering System
- 1995
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 1996
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 1997
- 1997_Q45_Body_Repair_Manual.pdf
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 1998
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 1999
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 2000.0
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 2000.5
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 2001
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- 2002
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Suspension Control System
- Seat
- SRS Airbag
- Wiper and Washer
- 2003
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- 2004
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- 2005
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
- 2006
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Wiper and Washer
Boasting top rankings in the IIHS safety ratings, and arguably one of the more handsome cars in its class, Infiniti added a new long-wheelbase (Q70L) version in 2015.
- 2014
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2015
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Drive Mode System
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2016
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Drive Mode System
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
INFINITI CROSSOVERS AND SUVS
There are many technological and safety options available, such as lane departure warning, lane departure prevention, blind spot warning, Bose stereo, an updated version of ATTESSA, memory seats , and a barrage of curtain and side airbags. The EX35/37 is a graduated G37 loaded with enjoyable luxurious extras.
- 2008
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- QR.pdf
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2009
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2010
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2010 Accessory
- 2011
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2012
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2013
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
The next generation FX came out in the 2009 model year. The better selling V6 version remained the FX35, but the V8 model was renamed FX50, due to an engine change to a new 5.0L V8, which put out close to 400 hp, and a smoother shifting 7 speed automatic transmission. The exterior looks were softened a bit, the interior was upgraded in design and material, and the suspension was upgraded improving what was already a pretty good ride with decent handling. A minor facelift followed in 2012. But in 2014, Infiniti renamed its entire product line using the letter Q plus 2 digit multiples of 10. So the FX37 and FX50 became the QX70.
- 2003 FX45-35
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2004.0 FX45-35
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2004.5 FX45-35
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2005 FX45-35
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2006 FX45-35
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2007 FX45-35
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2008 FX45-35
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2009
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2010
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2011
- Brake System
- Charging System
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- Maintenance
- Power Outlet
- Rear Axle
- Rear Suspension
- Seat Belt
- SRS Airbag
- Steering System
- Starting System
- 2012
- Brake System
- Charging System
- Defogger
- Exhaust System
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- SRS Airbag
- Steering System
- Starting System
- 2014
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2015
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2013
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Drive Mode System
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- jx_tow_hitch_finisher.pdf
- jx_tow_hitch_receiver.pdf
- jx_trailer_hitch_harness.pdf
- 1997
- 1997-QX4_Body_Repair_Manual.pdf
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- Transfer
- 1998
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- Transfer
- 1999
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- Maintenance
- Restraint System
- Steering System
- Supplement.pdf
- Transfer
- 2000
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- Maintenance
- Restraint System
- Steering System
- Transfer
- 2001
- Accelerator Control, Fuel & Exhaust Systems.pdf
- Alphabetical Index.pdf
- Automatic Transmission.pdf
- Body & Trim.pdf
- Brake System.pdf
- Electrical System.pdf
- Engine Control System.pdf
- Engine Lubrication & Cooling Systems.pdf
- Engine Mechanical.pdf
- Front & Rear Axle.pdf
- Front & Rear Suspension.pdf
- General Information.pdf
- Heater & Air Conditioner.pdf
- Maintenance.pdf
- Propeller Shaft & Differential Carrier.pdf
- Quick Reference Index.pdf
- Restraint System.pdf
- Starting & Charging System.pdf
- Steering System.pdf
- Transfer.pdf
- foldout.pdf
- 2001.5
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- foldout.pdf
- Maintenance
- Restraint System
- Steering System
- Transfer
- 2002
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- Maintenance
- Restraint System
- Steering System
- Transfer
- 2003
- Brake System
- Body and Trim
- Electrical System
- Engine Mechanical
- Maintenance
- Restraint System
- Steering System
- Transfer
- Recalls
- 2004
- Adjustable Pedal
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2005
- Adjustable Pedal
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- ffd.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2006
- Adjustable Pedal
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- FFD.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2007
- Adjustable Pedal
- Brake System
- Engine Mechanical
- Exhaust System
- Front Axle
- FFD.pdf
- Fuel System
- Front Suspension
- Instrument Panel
- LAN System
- Lighting System
- Maintenance
- Propeller Shaft
- Rear Axle
- Roof
- Rear Final Drive
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Transfer
- Wiper and Washer
- 2008
- Adjustable Pedal
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2009
- Adjustable Pedal
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2010
- Adjustable Pedal
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2011
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2012
- Brake System
- Charging System
- Defogger
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2013
- Brake System
- Charging System
- Defogger
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Instrument Panel
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
Infiniti’s smallest luxury crossover is still a practical size, and still turns heads – but where the QX50 really shines is on the interior – a perennial favorite among journalists. It’s flush with ornate details, rich colors and loads of technological toys befitting a vehicle twice its price.
- 2014
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2015
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2016
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- Sonar System
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
Infiniti sticks with their ubiquitous 3.5-liter V6 with 265 horsepower, providing adequate acceleration. Front wheel drive is standard, with an all wheel drive model available for folks in snow and ice areas. The QX60 Hybrid is powered by a supercharged 2.5-liter four-cylinder, along with an electric motor to produce a combined 250 horsepower and 243 lb-ft of torque, but fuel economy is almost identical to the V6 model.
- 2014
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2015
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Drive Mode System
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2016
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Drive Mode System
- Engine Mechanical
- Exhaust System
From the 2014 model, everything carried over for the 2015 model year… except the previously available 5.0-liter V8. All 2015 Infiniti QX70 models come equipped with the 3.7-liter V6 that develops 325 horsepower and 267 pound-feet of torque. A seven-speed automatic with a manual shift feature is the only transmission offered. Rear-wheel drive is standard, while all-wheel drive is optional. We’d take the QX70 with all-wheel drive and the 3.7-liter, which moves the big Infiniti 0-60 in just over 6 seconds. The downshift rev matching function adds to the driving enjoyment, especially in twisty roads and when darting through suburbia.
- 2014
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2015
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2014
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
- 2015
- Brake System
- Charging System
- Defogger
- Door and Lock
- Driveline
- Engine Mechanical
- Exhaust System
- Exterior
- Front Axle
- Fuel System
- Front Suspension
- Horn
- Interior
- Instrument Panel
- LAN System
- Maintenance
- Mirrors
- Power Outlet
- Rear Axle
- Roof
- Rear Suspension
- Seat Belt
- Seat
- SRS Airbag
- Steering System
- Starting System
- Wiper and Washer
What is a Factory Service Manual?
If you plan to do your own work on your Infiniti, whether it be routine maintenance or more in-depth projects, you’ll want to have access to a Factory Service Manual (FSM). These manuals are significantly more accurate than a Haynes or Chiltons manual, since the information is developed by the manufacturer to be used by factory-trained technicians.
Click to read –> How To Use an Infiniti Factory Service Manual
Inside each FSM, you’ll find repair information that the dealer-trained service technicians use everyday. While the FSM is intended for professionally-trained technicians with high levels of automotive experience and skill, don’t let that scare you. Even if you’re not an advanced do-it-yourself owner, we’re here to help.
Another benefit of having an FSM on hand is that occasionally, reference will be made to special tools and other information uniquely known by the dealership service centers, as well as additional troubleshooting tips, routine maintenance hints, and model-specific repair information.
Should I buy an Infiniti FSM?
Don’t be fooled into buying a digital copy on CD from auction sites like eBay. We provide our members access to the same factory-published FSM for free. [NOTE: These pdf files are marked for identification. Any reselling of these documents WILL be reported to eBay and Nissan!]
When you’re ready to begin your project, find the appropriate section of the FSM, and print the relevant pages you will need. This way, you’ll have it at your fingertips in the garage for easy and quick reference.
Cool! How can I thank you enough?
While you’re completing your project, take pictures as you go, and write up the process. Send it over to us at [email protected], and we’ll convert it to an article so that everyone can benefit from it for years to come. You’ll be contributing to the community, helping out your fellow Infiniti enthusiasts, and we might even send you some free goodies for your efforts!
Mistakes: Occasionally, you may run across a mistake or misprint in the FSM. While this is rare, we certainly like to know about it. Feel free to email us at [email protected] if you find something you think might be inaccurate.
Nissan service manuals
Datsun service manuals
