NICO Club
Nissan Forums | Infiniti Forums
Repairing Power Window Amp
December 10, 2009 by Aaron
by Justin8763
Overview:
Your dead power window solution could be as simple as a bad amp. Repair it!
Difficulty: **
Time: 1 hour
Cost: less than $10
Tools:
– Soldering Iron
– Phillips and flathead screwdrivers
Materials:
– Solder
Procedure:
First, remove your door panel and locate your window amp box. On an s14, it should look like this:
after removing it, you gotta pry the black face with the 8 prongs off. there are snaps at these locations on the box. I kinda chipped of a bit of it cause I was rushing a bit.
After you open it up, CAREFULLY pull out the circuit board…
Flip it over and take a close look. You can see a broken connection that is easily fixable.
Heat up your soldering iron, and solder the broken connection, something like this…
let the solder cool for a few seconds, and slide the board back in! you might have some trouble if its the same connection as mine, since the sides of the box hold the board in. I had to resolder thinner to let it slide in. put it back together and roll down your window and enjoy the breeze! If you discover it is a bad connection, and follow these steps to fix it, you save yourself ~$160 from the dealer or ~$60 from ordering it online!
I hope this helps…!
No related posts.
Filed Under: 240sx Articles
1987 Nissan Full Lineup Dealership Brochure
Strategic Shopping
Be Aware – Scammers Targeting Car Sellers
Battery Life Information for your Nissan Vehicle
Checking Tire Pressures – Why it’s Important
DIY Replace Drive Belts and Idler Pully on VQ35 Pathfinder
Could This Be the Best $30 You Spend on your Truck?
Roadmaster Active Suspension for Project Titan
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc. They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti. Information Copyright © 2000-2018 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
