Find related tutorials and information on your vehicle in NICOclub’s Nissan Forums & Infiniti Forums |
Window Operation
If the windows will not operate in the Auto-Mode and any of the following conditions have occurred, the windows should be initialized:
- Battery cable is disconnected
- Power window switch connector is disconnected
- Power window regulator is replaced
- Power window motor is replaced
- Window glass is removed
- Window glass run rubber is replaced
- Power window fuse is blown
Window Initialization Procedure
- Turn the Ignition switch “ON”.
- Open the window more than half way using manual-switch (NOT Auto-Mode) operation.
- NOTE: If the window is already open more than half way, go to step 3.
- Close the window using the manual-switch operation and hold the switch UP for 3 to 4 seconds after the
glass reaches the fully closed position. - Confirm the window you are working on is operating properly.
- Then, confirm all other windows are operating properly.
Sunroof Operation
If the sunroof does not operate properly, and any of the following conditions have occurred, the sunroof should be initialized:
- Sunroof motor is replaced
- Sunroof anti pinch function is activated for more than 5 seconds continuously
- Sunroof auto-open and auto-close function does not operate
Sunroof Initialization Procedure
- Fully close the sunroof. If necessary, press the Close switch several times until the roof is completely closed.
- Press and hold the Close switch for 3 to 4 seconds.
- Confirm the automatic operation of the sunroof works properly.
