Some Z owners are lucky enough to have the padded arm rest on their interior door panels, but most Z32’s did not come with them…but you can easily make your own if you have some handyman/hobbyist skills, and access to some hobbyist type tools. Here’s what we’re going to make: You’ll need: 1. 14″X14″X1/2″ plywood […]
Do It Yourself Shifter Boot and Arm Rest Install – Altima Coupe
Overview: This DIY is to help install a ShiftStyle or similar product on the Altima Coupe Difficulty:2 Time:60 minutes Cost:$50 – $100 Materials: Shift boot and arm rest Tools: flat screwdriver, philips screw driver Procedure This procedure should help guide you to remove and replace the shift boot and/or arm rest on the altima coupe […]
