240sx Dimmer Switch Bulb Replacement You have two choices. You can buy another bulb and holder from the dealer, or order it online. It’s your choice, but the dealer route is more expensive but less time consuming. Here’s the bulb you need. Properly cut down. Dimmer Switch Remove the bulb with a screwdriver and a set of […]
Nissan Versa Installing LEDs in the window switches.
How to install LEDs in your Versa window switches. I took apart my armrests and looked at the circuit. I discovered that the passenger side has prewiring for LED lights, I purchased blue smt LEDS, resisters and 30 gauge wire and figured out with a multimeter the power source in the pc board and I […]
