Some Z owners are lucky enough to have the padded arm rest on their interior door panels, but most Z32’s did not come with them…but you can easily make your own if you have some handyman/hobbyist skills, and access to some hobbyist type tools. Here’s what we’re going to make: You’ll need: 1. 14″X14″X1/2″ plywood […]
Removing Altima Coupe Door Panels
Ok, how to remove door panels. Here we go: First, pry off the cover inside the door handle. Then unscrew the screw inside. Now, pry up the cover starting from the bottom. Once unclipped, undo the wire connection. Then place the assembly aside. Now pry off the trim peace, starting from the rear, and moving […]
