Fog Light Modification By:NISTECH NOTE:This is for a Pathfinder / QX4, but MAY be adaptable to other Nissan models as well. The fog lamp relay is powered through the headlamp relay, so your headlights would need to be on to power the fog lamp relay. The ground side of the relay goes through the foglamp […]
G37 Headlight Foglight Parking light Install
1. Loosen lug nuts on a front tire (I started with the left front one) 2. Jack car up and remove lug nuts and tire 3. Pop out the three plastic clips on the wheel well so it can be folded behind the brake. After that, you will see this once you look in there […]
Q45 Fog Light Modification
Fog Light Modification Infiniti Fourth Generation Q45 Wiring Relays Tools Electrical Battery Cable Yellow Customize Personal Soldering Wire Taps Crimping Splicing Strippers Connectors Bundle Cut Strip Shock Short Jumper I thought I had done this already, but could not find it. I am doing it over due to requests I keep getting of how to […]
