Q45 Knock Sensors By: Wes Stinson A common problem that has plagued many Nissan and Infiniti vehicles is problems with the knock sensors (also called KS). Bad KS will not throw a CEL (Check Engine Light). Symptoms include loss or poor acceleration and can also cause bucking/jerking problems. Generally, knock sensors do not cause the […]
Replacing Infiniti J30 Knock sensors
J30 Knock Sensors By: Wes Stinson A common problem that has plagued many Nissan and Infiniti vehicles is problem with the knock sensors (also called KS). Bad KS will not throw a CEL (Check Engine Light). Symptoms include loss or poor acceleration and can also cause bucking/jerking problems. Generally, knock sensors do not cause the […]
