Fog Light Modification By:NISTECH NOTE:This is for a Pathfinder / QX4, but MAY be adaptable to other Nissan models as well. The fog lamp relay is powered through the headlamp relay, so your headlights would need to be on to power the fog lamp relay. The ground side of the relay goes through the foglamp […]
G35 Bulb replacement stock part numbers
Low beam headlampHID-D2R High beam headlamp9003 Parking light168 Front turn signal7440 Rear turn signal7440 Tail lightLED Stop lightLED High mount stop lightLED Fog/Driving light9003 License plate168 Back up light921 Front sidemarker194 Rear sidemarker194 Map lightDE3175 Dome lightDE3175 Step/Courtesy lightDE3022 Trunk/Cargo area158
