The following directions can be utilized in the installation of an Addco RSB onto a 5th Generation (2000-2003) Maxima. Installation onto a 4th generation (1995-1999) should be similar. It is recommended that two people perform the installation, but, one person could accomplish the task. Please view pictures with steps for additional detailed information. Step 1. […]
Altima Coupe Racingline Rear Endlinks Install
You need– TWO 2-ton jackstands– ONE jack from the trunk– ONE ratchet with a 17mm socket– ONE 17mm wrench– ONE 19mm wrench OR locking pliers (I used the locking pliers) first you are going to need to jack the car up. Jacking points: You take your cheapo jack from the trunk of the car underneath […]
Cheap 240sx Sway Bar Link Upgrade
How to: Cheap 240SX Sway Bar End Link Upgrade! BY: Dano Our cars are old, so are the stock rubber bushings. Chances are your stock swaybar endlinks bushings are dried, cracked and rotting. Here’s a cheap solution, AND you can get all the parts from your local Autozone for under $30! Tools and Supplies -12mm […]
Whiteline Flatout Anchor Locks: Taking the Sway Out of Your Sway Bar
Whiteline Flatout Sway Bar Anchor Locks Installation by Rev D21 Kit Info: Whiteline Flatout Part Number KLL120 for 19-20mm thick sway bars Test Subject: 1995 Nissan 2WD D21 Hardbody with Hellwig 7531 Rear Sway Bar Installation Time: 15 Minutes (Including Setup Time) Difficulty: Easy Whiteline Flatout makes anchor locks to help cut down on side […]
