by: rockchucker After replacing all of my suspension components on my 300ZX I found that my wheel offset was not enough to bring my front wheel flush with the body… So I measured the distance it was off and ordered a Version 1 Ichiba Hubcentric 15mm spacer kit with new longer wheel studs. The version […]
Z32: Install SPL Subframe Spacers (8 Piece)
Applied Vehicle(s): Nissan 300zx Difficulty Rating: Estimated Labor Time: 1½ hours Written By: es.biggs Estimated Total Cost: $95.00 Find related tutorials and information on your vehicle in NICOclub’s Nissan Forums & Infiniti Forums Tools I used: Jack Jack stands or ramps Small block of wood (for jacking up the differential) 3/8″ Ratchet 14mm, 17mm sockets […]
Nissan Wheel Selection Guide: Fitment, Offset and Bolt Patterns
What do you need to know when selecting new wheels for your car or truck? Here are the basics! Bolt Pattern The bolt pattern or bolt circle is an imaginary circular diameter formed by the centers of the wheel lugs. Nissan and Infiniti vehicles come with bolt patterns utilizing 4, 5, or 6 lug holes […]
