Because so many styles of OEM wheels were available on the 350Z throughout its production I thought it might be time for a list of the wheels with images and their physical characteristics.
OEM 17″ Alloy from Base & Enthusiast models from ’03 – ’05 (17×7.5 30mm / offset 17×8 33 mm offset)
Touring Version One from Performance & Touring models from ’03 – ’05 (18×8 30mm offset / 18×8 30mm offset) The front and rear wheel sizes are the same, in order to keep the VDC happy the stagger comes from different tire sizes.
Track Version One from the Track model from ’03 – ’05 (18×8 30mm offset / 18×8.5 33mm offset)
Touring Version Two initially available on the ’05 35th Anniversary model and standard on the Base, Enthusiast & Touring models starting in ’06 (18×8 30mm offset / 18×8.5 33mm offset)
Track Version Two standard on the Track & Grand Touring models starting in ’06 (18×9 30mm offset / 19×10 30mm offset)
Nismo Edition Track Wheel standard on the Nismo models starting in ’06 (18×9 30mm offset / 19×10 30mm offset – exactly the same specs as the Track Version 2 except the different appearance)
Do you own a 350Z? Join us in the Nissan 350Z Forum!
Questions? Comments? Just want to discuss wheels and tires for the 350Z? Here’s where: 350Z Wheels, Tires, and Performance Technical Discussions
