Energy Suspension Bushing Installation Guide
December 10, 2009 by Aaron
by:Kenrik
Sway Bar End Link
Purpose: Sway bar endlinks connect the ends of the sway bars to the struts.
Tools: 14mm Socket
Parts
Assembled
Install
Now do the other side!
Finished!
_____________________________________
Tension Rod
Purpose:
Tools: 17mm Socket/Extension, Blow torch, Sawzaw, Hammer, Flathead Scredriver, File, and depending on the kit a press*
*press not required for the “new” 3pcs kit.
Parts
Bushing Removal:
Step one: Set the ***** on Fire!
Step Two: Cut the inner metal ring (do not cut the outer metal) with a Sawzaw in about four places
Step Three: Pound the inner ring out with a hammer and flathead
Step Four: Smooth the inside with a file and install grease
Step Five: Install bushings and center copper piece
Hmm… Burning rubber! Smells like a drift event!
Assembled
Install:
Reverse of removal
Finished!
Lower Control Arm
Purpose:
Location: Attached to the front support, wheel, and tension rod
Tools: 17mm Socket, C Clamp, Torch, Screwdriver, Soap
Done! no press required!
Finished!
  • Clean Your Engine With Deep Creep / SeaFoam (video)
  • Sparco Steering Wheel Install
  • Buying a Custom Car Cover
  • Vendor Spotlight: Wiring Specialties
  • Oilblocker Oil Change Accessory
  • Meet the Builder: Bluefire Machine Works
  • Wireless OBD2 Scan Tool – Why Don’t You Have One?
  • Orange is the new Purple – Shop Degreaser Challenge
Filed Under: General Automotive, Product Review
