1. Loosen lug nuts on a front tire (I started with the left front one)
2. Jack car up and remove lug nuts and tire
3. Pop out the three plastic clips on the wheel well so it can be folded behind the brake. After that, you will see this once you look in there
Circled in red is the HID, Blue is the fog light, and Yellow is your parking lights
4. Next step is to remove the covers of the HID’s and the fogs, just twist left and they should pop off, and will look like this
Note: Careful with the fog cover because, wires run through it, so don’t rip them out
Now for each of the three bulbs its a little different:
HID’s
– Twist HID connection to the left (circled in purple)
After this, you will need to remove the screw using a small phillips head. After that, the light should come out easily.
Note: Be careful because the oil from your fingers will damage the bulb, so don’t touch it
Then, insert new bulb and do the steps in reverse
Fogs:
– Unscrew the 2 screws using a small phillips head. Bulb should easily come out. You can leave the wiring connected so it won’t be a pain to reconnect the wire after you put it back in. (fogs are circled in blue)
Insert new bulb then reverse the steps
Parking:
-This is the toughest to get to because the area is so tight. A long black plastic piece sticks out, so take that and twist to the left. Your bulb and socket will come out with it. (The area is circled in yellow)
Now insert new bulb and do the steps in reverse.
Insert new bulb
Article by: CYO44Baseball32
