G37 Removing Sports Seat Thigh Bolsters
December 10, 2009 by admin
Those of you with G37 sports seats may have noticed that the thigh bolsters are a little tight. A little research has yielded that the USDM and JDM seats are the same size. So Nissan/Infiniti probably designed them more for the small statured Japanese businessman instead of the larger statured American. You HAD two options:
-Lose some weight (hopefully your frame isn’t too wide)
-Deal with the lack of comfort
Here’s a third option…
The G37 sports seats have small steel support braces on the thigh bolsters. These braces are 1″ x 6″ steel plates that are welded to the seat frame and push against the bolsters (and your thighs) to hold you like a hot dog in a tiny bun.
Removing the braces allows for a more comfortable seat bottom and will not affect the seat’s structure. This should be a “stealth” mod and you will only notice it when you sit in the seat and enjoy the comfort.
In order to remove the braces, you must remove the seat and the lower upholstery (Be sure to place the seat on a soft surface to prevent leather damage). Cut the braces off of the frame, then reassemble.
The result will be a lower seat that is very comparable to the non-sports seat, with comfortable thigh support and the added support of the upper bolsters.
For those of you who aren’t comfortable removing your seats and tearing them apart, contact your local auto upholstery shops. Ask them if they have experience removing the bolster braces off of G37s or other sports cars (This is a common Porsche mod).
  • Infiniti G37 Grounding Wire Install
  • Installing a SPC Rear Camber Kit and Toe Bolts on an Inifiniti G35
  • Retiming procedure for an Infiniti G35 and G37 Window and Moonroof
  • 350Z and G35 Dual Short Ram Intake with OEM Piping
  • Project G37 To the Edge of the World and Back
  • G35 Exhaust install
  • G35 Stillen or POP Charger Intake install
  • G37 Headlight Foglight Parking light Install
  • Installing an Under Drive Lightweight Pulley on an Infiniti G35
  • Infiniti G37 Sedan Navigation Bypass Mod
Filed Under: G35-G37 Articles Tagged With: comfortable seat, G35, g37, how to, infiniti, Nissan, seat, thigh bolster, thigh support
