There needs to be some clarification on the letter customers are receiving. First thing they do NOT cover the Brembo brake systems. We have had many of the G35’s have premature brake wear and Infiniti has been addressed the concern by customers, and us technicians as well. We have many G35’s visit our service department […]
Project G37 Brakes and Clutch Upgrades Part III
NICOclub’s Project G37 Gets Brake and Clutch Work During our first installment of Project G37, we began by taking the car to the track and determining its weak points in stock trim. We found a few things that we knew needed to address as our first mods on the car. First we determined the car […]
Nissan Rogue Disc Brake Service
Nissan Rogue Disc Brake Service Overview: This how-to is a step-by-step procedure for cleaning and servicing disc brakes on the Nissan Rogue. Actually this could be applied to nearly any vehicle with disc brakes. Difficulty: 3/4 Time: It takes approximately one hour to do all 4 brakes. Newbies should expect to take at least 2-3 […]
2004 Nissan 350Z – NICOclub Ride of the Month September 2005
ATI ProCharger w/ 9psi pully Shielded CAS wire Custom Grounding Kit AAM Y Pipe High flow Cats J&S Ultra Safeguard AAM ECU reflash B&M Short Shift Kit GReddy AirFlow Plate EGT Gauge in Drivers door AC vent Plenum Spacer Greddy Oil Catch Can Koni 8241 adjustable shocks Greddy Blowoff Valve 2004 Nissan 350Z – Owned […]
300ZX Brake Upgrade for FRS/BRZ – Part 2
300zx Brake Upgrade for FRS/BRZ – Part 2 – How will they work? Assuming you’ve already read Part 1 of the 300ZX Brake Upgrade for FRS/BRZ, let’s cover the rest of this system. In this article I will talk about how this braking system performs in comparison to stock. I will try to explain some […]
Would you like better brakes for your BRZ/FRS without spending $2k or more? In this article i will show you many options for brake upgrades ranging from professional aftermarket kits to a simple OEM upgrade.
