This article is to assist you in changing the air filter in a VQ35HR. Yesterday I decided to change the air filters on the Z. I had a spare hour till the GF came down so I figured this would be something I could do that would take an hour. As it turns out, I […]
Nissan Altima 3.5 DIY Oil Change Procedure
This tutorial will help guide you to change your oil on a 3.5 Altima.You will need the following items to accomplish this task: 5 quarts of oil 1 oil filter 1 new washer 2 floor jacks and/or ramps 14mm socket Oil filter wrench Oil drip tray Rags Funnel Step 1:Line your car up and drive […]
Do It Yourself Bumper Removal – Nissan Altima
Overview: This DIY is to help you remove the front bumper of any 1st generation Nissan Altima. Difficulty:1 Time:30 minutes Cost: $0.00 Materials: none Tools: 10MM socket / Ratchet w/ extension, Flat head screwdriver, Philips screwdriver Procedure: 1. You’ll need to get to some screws and bolts under your car so you might want to […]
Do it Yourself CVT Knob Removal and Bulb Replacement
Overview: This DIY is to help Remove the shift knob on a CVT and replace the 194 Bulb with a 194 LED bulb Difficulty: 1 Time: 15 minutes Cost: $5 Materials: 194 LED bulb Tools: flat screwdriver, rag Procedure First step is to pull down with a firm grip on the little chrome looking plastic […]
Do It Yourself Shifter Boot and Arm Rest Install – Altima Coupe
Overview: This DIY is to help install a ShiftStyle or similar product on the Altima Coupe Difficulty:2 Time:60 minutes Cost:$50 – $100 Materials: Shift boot and arm rest Tools: flat screwdriver, philips screw driver Procedure This procedure should help guide you to remove and replace the shift boot and/or arm rest on the altima coupe […]
