Fuel Injector Replacement – 3rd Generation w/VE30DE Note that this information is related to the 92-94 VE30DE engine, although I’m sure some of it can be applied to the VG30E engine, as well. If you have any doubts on your capability in performing this replacement, take your car to a certified mechanic. What you need: […]
How to calculate injector size
Calculating Injector Size and Metric Conversions You will need access to a dyno to properly do this. Step 1: Determine the horsepower of your engine. To determine the horsepower your engine is producing at the crank, you should have your vehicle dyno tested. Step 2: Determine your approximate BSFC or Brake Specific Fuel Consumption. BSFC […]
