Resolving Rough IdleBy Jesda Gulati Fuel Injectors – Bad gas or regional mixtures tend to result inearly injector failures. A fuel smell in the cabin also hintsat injector problems. Non-OEM injectors are not recommended.Learn how to test your injectors Fuel System- Purchase a can of BG44kfrom Infiniti of Scottsdale and add it to a 3/4 […]
Infiniti J30-Diagnosing a Faulty Fuel Injector
Removing a fuel injector without removing the plenum isn’t without risk. Grinding of the upper plenum will be involved with the possibility of completely grinding through the plenum wall thus ruining the plenum. The trade off is several hours of labor and many dollars saved by not having to replacing a slew of gaskets and […]
