Applied Vehicle(s): Infiniti Q45 Difficulty Rating: Estimated Labor Time: 2½ hours Written By: subtle_driver Estimated Total Cost: $60.00 Find related tutorials and information on your vehicle in NICOclub’s Nissan Forums & Infiniti Forums I acquired some subframe collars from Powered by Max (see product link at bottom of article), thanks to my friend Will – I’m helping him […]
1990 Nissan Silvia : NICOclub Ride of the Month | rexhunta
1990 Nissan Silvia Owned by : rexhunta 1990 Nissan “E-KS13” Silvia Q’s painted in Bluish Silver 2 tone. Started life in Japan as a Non-turbo, Automatic CA18DE. Oh the joys that would have been. When it got here to Australia, the original owner had the engine and gearbox changed to a CA18DET with […]
1991 240sx Coupe : NICOclub Ride of the Month | rico05
1991 240sx Coupe – Owned by Rick Novak (rico05) Car: 1991 MS13 SE Coupe Interior Mods: Peyton wood steering wheel Nismo carbon horn button Nismo resin “dildo” shift knob Autometer Ultra-Lite Pro Comp water temp/boost gauges 180SX (JDM) throttle pedal (closer to brake pedal) HKS E-01 turbo timer Exterior Mods: Sleepy eyes Xenon front lip […]
1991 Nissan 240sx NICO Forums Ride of the Month for April 2008
James Sisson (PapaSmurf2k3) 1991 Nissan 240sx I originally purchased my 91 240sx back in 2002. I was 17 and my first car was a 1987 Nissan Maxima that I picked up in non running condition for $100. I learned a good deal about car mechanics on that car, and it was pretty nice (power […]
Ride of the Month August 2005 – 1997 Nissan 240sx
1997 Nissan 240sx – Owned by : colies97~240sx A little history: I bought my 240 back in September of 2000. I had sold my previous car on a whim and just happened to go by a local Nissan dealership the next day and found the 240. It was base and automatic with 35k. Since then […]
1992 240sx Convertible: NICOclub Ride of the Month | jdms13rhd
JDM 240sx Convertible – Owned by : Allen (jdms13rhd) I got the car from WorldCarLink Japan. I work for the company now, go figure. The car was already in Canada when I bought it and I was in the market for something faster than a Honda. I got it Sept 2003 when it was […]
Installing SPL Coilovers on S14
Applied Vehicle(s): Nissan 240SX Difficulty Rating: Estimated Labor Time: 4 hours Written By: Unknown Estimated Total Cost: $750.00 – $3000.00 Find related tutorials and information on your vehicle in NICOclub’s Nissan Forums & Infiniti Forums Overview: Coilovers allow the ultimate in adjustable suspension performance for your car, and they are easier to install than a […]
How To Remove Cylinder Head from a KA24DE Engine
KA24DE Engine N/A 20 minutes NICOclub Rating System S13xCrazy Is it rocket science? Nope. Did I figure a couple people would be beneficial from it? Absolutely. If nothing else, this will give you an idea of what you are up against and shows how easy it really is. I have owned about 10 240sx, and […]
Direct Bolt Up 180sx 280mm Brake Swap WITH NO OVERHANG
So I have finally figured it out! Everyone has been doing what the article for 180sx swap tells them to do. That is, to use the 93-01 Altima rotors and calipers or 89-99 Maxima calipers (since the Altima and Maxima used the same ones). However this results with a 6mm overhang which, as I […]
How To Fix an Incorrectly Installed Lower Timing Chain
1991-1994 Nissan 240sx This article will cover how to fix an incorrectly installed lower timing chain without removing the lower front cover. If you have to turn your distributor all the way to the right or left to get it close to correct timing, chances are this is your problem. If you can not get […]
