Road Trip Rules and Etiquette By:Jesda I’ve covered 20,000 miles crossing the country in various directions, and I’m about to tack on another 2,000 miles this weekend. Its time I laid down some rules and guidelines for drivers and passengers. Drivers:1) Know the mechanical condition of your car! There’s no excuse for a breakdown. In […]
Nissan Versa Installing an iPod adapter
Parts: iPod gateway module kit (999U7-ST000) N-Bus Harness for iPod gateway (999U7-VT000) N-Bus Harness for SAT radio (999U7-VT001) Tools used: Phillips Screwdriver (#2), Drill with 1/8” and ¾” drill bits, 10mm wrench Vehicle Prep: 1. Apply parking brake 2. Record radio presets (as the negative battery cable will be disconnected) 3. Make sure the car […]
Altima AVIC F90BT and XM HD Tuner Install Microphone replacment
Overview: This DIY shows how to install a AVIC-F90BT, XM/HD tuner and Stock Microphone replacement Difficulty: 3 (Basic knowledge of automotive electrical wiring is needed) Time: 2 hours Cost:$500 – $1K (depending where you buy you’re supply) Materials: AVIC-F90BT, wire kit, Satellite radio kit Tools: wire stripper, electrical tape, solderless terminals, ohm/volt meter, Uni-bit/Step-bit or […]
