OEM part # is 22401-5m015 TOOLS: 6 NGK LFR6AIX-11 Iridium IX Sparkplugs (these are 1 heat range cooler than stock)3/8″ Rachet3/8″ long extension (at least ten inches)10mm socket16mm “deep” socket (or “sparkplug socket”)Magnetic pick up tool3-prong grabber (optional, you’ll need it if you don’t have a “sparkplug socket”)PliersTorque Wrench Most people would have these tools […]
240sx Distributor Timing
The purpose of this article is to show how to get your 240sx distributor in the correct timing position. Take your time and you’ll get it right! Locate your front main pulley Understand the markings on the pulley, if you can’t see them, turn with a socket wrench clockwise (pretty tough) Make sure that you […]
How To Fix an Incorrectly Installed Lower Timing Chain
1991-1994 Nissan 240sx This article will cover how to fix an incorrectly installed lower timing chain without removing the lower front cover. If you have to turn your distributor all the way to the right or left to get it close to correct timing, chances are this is your problem. If you can not get […]
