Low beam headlampHID-D2R High beam headlamp9003 Parking light168 Front turn signal7440 Rear turn signal7440 Tail lightLED Stop lightLED High mount stop lightLED Fog/Driving light9003 License plate168 Back up light921 Front sidemarker194 Rear sidemarker194 Map lightDE3175 Dome lightDE3175 Step/Courtesy lightDE3022 Trunk/Cargo area158
G37 Headlight Foglight Parking light Install
1. Loosen lug nuts on a front tire (I started with the left front one) 2. Jack car up and remove lug nuts and tire 3. Pop out the three plastic clips on the wheel well so it can be folded behind the brake. After that, you will see this once you look in there […]
Altima Coupe How to Install Sequential Turn Signals
How to Install Sequential Turn Signals This article shows you how to install Oznium Orange flexible LED strips to be used as sequential turn signals on your Nissan Altima. Ok Guys and Girls, I had to do it! Especially since I told LBC about it. The whole process takes about 4 hours to do. Probably […]
Altima Coupe Painting Taillights
In this article we will be painting a set a Altima Coupe taillights. This is an alternative to using vinyl overlays as it is easier to apply and slightly more permanent. Note: Check with your local jurisdiction before performing this as it may not be legal in all states. Skill Level 1 of 5 Time […]
