Maxima Y-pipe and cat installation By: beancooker 1. Remove all heat shields (10mm wrench). 2. Remove O2 sensors. 3.Spray penetrating oil on all bolts to be taken out. YOU WILL NEED A PIVOTING ADAPTER FOR YOUR SOCKET WRENCH. Remove 3 bolts on front bank, 3 bolts on rear bank and 2 bolts on cat. 14mm […]
G35 Exhaust install
This is a how to for most G35 coupe exhaust installs. I used the Greddy EVO2 dual exhaust which requires relocating the evaporative canister. IF YOU ARE NOT MECHANICALLY INCLINED, FIND A FRIEND WHO IS TO HELP YOU. THIS IS MORE DIFFICULT THAN AN INTAKE, BUT IS NOT NECESSARY TO PAY A SHOP TO INSTALL. […]
